Base currency
OneBox Corp - Інтегратор
This should be done by the developers, write here what currency you need to change to and I think they will help you)
10.09.2020, 12:29
Which account do you mean. If this is a contact card, then you can display the "Currency" field (a standard field, you can select it in any universal block of the contact card interface) and select any currency that is in the settings.
Settings -> other -> Currencies.
10.09.2020, 12:31
No, not in the card to change. It is necessary to change the base currency of the entire account to Kazakhstani. I already added it. But there is no change.
In this case, do NOT delete all other currencies. And just add Kazakhstan and make it the base one.
10.09.2020, 12:40
Hello. When can I expect to change the base currency of my account?
16.09.2020, 11:35
