Process Commitment Error
I saw this when there is a discrepancy in the order and warehouses.
That is, it is possible that more goods were written off than there are in the order itself. Or vice versa.
Perhaps you deleted an item that was in the order and has already been written off?
In general, I advise you to check the list of goods in the order for compliance, and by warehouse.
01.09.2021, 15:16
OXID
1. Before writing here, I checked everything.
2. How are the obligations of the client related to what you wrote if they are LESS than the difference in the amount of the process and payments? Perhaps you should read the questions more carefully?
01.09.2021, 15:38
Well, at least there is accounting for warehouse operations in obligations, which can be limited by the corresponding checkboxes in the BP parameters https://zhiraf.crm-onebox.com/admin/shop/workflow/16/parameters/
01.09.2021, 15:53
Chausova Tamara
I just wrote that I had such a problem and because of what it was. Perhaps you should read the answers more carefully?
01.09.2021, 16:23
OneBox production
Please explain what you mean? Where in the BP parameters is the accounting of warehouse operations configured? I can't find anything similar What settings should be applied in this case?
01.09.2021, 18:00
Please explain what you mean? Where in the BP parameters is the accounting of warehouse operations configured? I don't find anything similar. What settings should be applied in this case?
At least there are checkboxes:
- Do not take into account warehouse operations when paying off our obligations
- Do not take into account warehouse operations when paying off client obligations
02.09.2021, 17:20
The answer is not correct! The issue is not resolved!
06.11.2021, 09:50
The commentary is not informative.
The more correctly you ask your question (what exactly you do not understand in my answer), the more correctly I will answer it.
08.11.2021, 14:15
Where are these checkboxes in the PSU settings?
16.02.2022, 12:44
