Good afternoon
There is such a task, to save an employee in the menu the finance page for a specific wallet and for today, so that he always sees the information for the current day. Moreover, if I enter https://crm.ohrana.ua/admin/shop/finance/?accountid%5B%5D=2&filterdatefrom=cdate&filterdateto=&, that is, I set filterdatefrom=cdate , then the list of payments for today is filtered and everything was would be great, but in the lower block where the balance at the beginning of the period / at the end of the period and the amount of input / output of payments are not considered values, I see http://joxi.ru/Dr8YD3EsJ3zwam. Tell me if there is any solution what to specify in the link to see the bottom part is correct?
Good afternoon There is such a task, to save an employee in the menu the finance page for a specific wallet and for today, so that he always sees the information for the current day. Moreover, if I enter https://crm.ohrana.ua/admin/shop/finance/?accountid%5B%5D=2&filterdatefrom=c... that is, I set filterdatefrom=cdate , then the list of payments for today is filtered and everything was would be great, but in the lower block where the balance at the beginning of the period / at the end of the period and the amount of input / output of payments are not considered values, I see http://joxi.ru/Dr8YD3EsJ3zwam. Tell me if there is any solution what to specify in the link to see the bottom part is correct?
To filter payments for the current day, use the link for the left menu /admin/shop/finance/?filterdatefrom=[cdate] 00:00&filterdateto=[cdate] 23:59&ok=1 The link you provided will not work to filter payments
Maria OneBox production wrote: To filter payments for the current day, use the link for the left menu /admin/shop/finance/?filterdatefrom=[cdate] 00:00&filterdateto=[cdate] 23:59&ok=1 The link you provided will not work to filter payments
If I specify such a link, I also do not receive balances for today and the amount of input and output of payments
Maria
If I specify such a link, I also do not receive balances for today and the amount of input and output of payments [file]9791[/file]
Maria OneBox production wrote: Can you tell me which menu item you are setting up?
Maria, now it's clear, saved the specified link in the menu and now it works. Thanks
Maria
