Good afternoon. I noticed changes in Onebox (yesterday and today, separators ".," were introduced), which greatly affect the automation of actions: Export of BP via XML, Export of payments via XML. The problem is that if the amount of the process or payment is floating and with a dot (instead of a comma), then it is difficult to work with such numbers / create reports. For example, Google Sheets does not want to recognize a number with a dot as a number and converts it to a date or converts it to its own amount. Neither changing to the US format, nor changing to a numeric format, nor other options helped.
It is a VERY big request to consider the possibility of automation in these actions, such as in Export of products to XML - "Price rounding accuracy", or choosing a period or comma as a separator. And do the same with Export of BP and Payments. Otherwise, these actions lose their usefulness...
Good afternoon. I noticed changes in Onebox (yesterday and today, separators ".," were introduced), which greatly affect the automation of actions: Export of BP via XML, Export of payments via XML. The problem is that if the amount of the process or payment is floating and with a dot (instead of a comma), then it is difficult to work with such numbers / create reports. For example, Google Sheets does not want to recognize a number with a dot as a number and converts it to a date or converts it to its own amount. Neither changing to the US format, nor changing to a numeric format, nor other options helped. It is a VERY big request to consider the possibility of automation in these actions, such as in Export of products to XML - "Price rounding accuracy", or choosing a period or comma as a separator. And do the same with Export of BP and Payments. Otherwise, these actions lose their usefulness...
