XML/JSON Business Process Integration (Import)
Hello
In "Automation" I launched "Integration of XML/JSON business processes (Import)". I noticed a missing field, stopped the integration by pressing the ON/OFF switch. But I noticed that the processes did not stop and objects continued to be imported.
Did I understand correctly that even if I switched the switch to OFF mode, the import will continue until it imports all the data from XML?
If so, how can I stop XML forcibly? Or rather, pause the import? And if so, then when I start the import again, will it continue from where it stopped or start importing again (and if there is a check mark in the settings, then if there are processes, it will be updated)?
If the import of processes has already been launched, and I have made some changes - added or deleted a field key and a field key in our OneBox, will the new fields be processed after the initially launched XML integration has been completed?
Pavel wrote:
I noticed a missing field and stopped the integration by pressing the ON/OFF switch.
it doesn't work like that
if the cron has already started and the action was enabled at the time of launch, it will work until the cron is completed
Pavel wrote:
If so, how can I forcefully stop the XML? Or more precisely, pause the import?
from the user's side - no
Pavel wrote:
And if this is possible, then when you start the import again, will it continue from where it stopped or will it start importing again (and if there is a check mark in the settings, then if there are processes, it will be updated)?
import processes the entire file according to the automation settings
the next time you run import
Donats 1
10 USD from Pavel
12.05.2025, 08:30
