I urgently need help - tracking of application statuses does not work, the stage does not switch
Sometimes the automation works correctly, but more often it doesn't.
1. Process https://one-box.shine-bright.com.ua/542654/
the application status has changed (screenshots), the action "Payment in installments Monobank / Get application status" does not work.
If you switch back to the stage with this action, it will work correctly.
2. https://one-box.shine-bright.com.ua/541672/
The application status has changed to "The PC credit transaction has been confirmed by the client", in the logs: [inputparams] => {"order_id":"cb97cd8a-0c0c-4b15-a7b8-3b090fb41a53","state":"IN_PROCESS","order_sub_state":"WAITING_FOR_STORE_CONFIRM","message":null}
but the action worked out the status "Waiting for confirmation from the client of the loan agreement in the monobank application"
I set up tracking at this stage too, but it doesn't work.
If you switch it back to the tracking stage, it will work correctly.
Resolved via TP
30.11.2024, 16:58
Volokhovich Evgeniy
Адміністратор
Rodion wrote:
Solved through TP
And what happened? describe please
03.12.2024, 15:00
access rights for managers to add payments with a new category were not added,
and at the stage there was an action of switching the parent process to the stage with the payment
03.12.2024, 21:08
Volokhovich Evgeniy
Адміністратор
thanks for the explanation!
03.12.2024, 22:32
