Help me understand how this parser works.
[file]22791[/file]
In this action there is a field: "Column number in file", it contains a footnote with information on filling this field:
[file]22791[/file]
"You must specify the column ordinal number in the file starting from 0"
[file]22791[/file]
In the file (payment register) I need to select the required column, starting from "A" - this is 0, "B", "C" "D". Column D will be number 3, is that correct?
[file]22791[/file]
Next, the action will check the specified column for the filled fields of the file and write to the selected additional field or will search for a process with this field if the checkbox "Search for a process by the specified field instead of writing the value" is checked
[file]22791[/file]
Do I understand correctly how this action works?
[file]22791[/file]
[file]22791[/file]
