The action does not work: Assign the process of purchasing products to an employee
Daily automation, action: Put the process of purchasing products on an employee
HERE: https://balistyka.1b.app/app/automatization/day/edit/
Previously, it worked in such a way that when the stock of the product was less than the minimum reserve, a task was created to purchase the missing product
The action with the current settings worked OK, but at a certain point in time, tasks for the responsible person stopped being automatically created.
Please help to fix it.
Try to remove the "Start time" setting, the action is set to automation once a day, this action can be set once an hour and there this setting will make more sense
20.08.2024, 13:03
Легеза Вячеслав iCOLOR OneBox
ФОП Легеза В.В.
Maria
removed Start time 09:00 as it stood
started the action forcibly
we control what will happen
20.08.2024, 13:37
ФОП Легеза В.В.
Maria
tried setting up the same action on hourly automation
ran it and it didn't work either, unfortunately
please tell me how to check when the action created the last tasks?
20.08.2024, 15:49
for example, here is the process created by this action https://balistyka.1b.app/97533/
or here is yesterday's https://balistyka.1b.app/97363/
the action works
21.08.2024, 10:33
ФОП Легеза В.В.
Maria
the action works
thank you sincerely
it seems that the issue is resolved
tried to configure the same action in parallel with slightly different settings
checked and works
21.08.2024, 10:37
