ERROR in triggering action: Change business process and status of current, parent and all subordinate tasks
Enabled the action at the subtask stage
Change the business process and status of the current, parent, and all child tasks
Since they found an error because the action did NOT work, they created a test procedure with the same action.
Such a decision still did not lead to the desired result.
It seems very likely that there is a bug in the operation of the action.
Logically, the parent task should be switched to the status Awaiting shipment, if such a task is in the status Calculated
See Screens
When we turn off an additional condition, but an important condition, everything switches to Ok.
Please help fix this error
Good day
Try adding a check mark in action settings https://i.imgur.com/xIA6W8J.png
08.01.2024, 10:41
Легеза Вячеслав iCOLOR OneBox
ФОП Легеза В.В.
Vasylyk Taras
The integrator wrote:
Good day
Thank you sincerely
really helped
08.01.2024, 11:50
