I am asking for help in creating a PREG template for creating a process with the ability to search for a client in contacts.
[file]21636[/file]
I use the block Turn a letter into a process, by which you need to create a process and find a contact, if it exists, or create a new contact (nounname).
[file]21636[/file]
1. It is necessary to extract the phone number that is in the subject of the letter and search for it
[file]21636[/file]
2. Is it possible to insert a file into the process so that it is not downloaded, but listened to as missed calls?
[file]21636[/file]
There is a recording of the answering machine. Thank you very much!
[file]21636[/file]
[file]21636[/file]
Vitaly Volodymyrovych Pcholkin wrote: 1. It is necessary to extract the phone number that is in the subject of the letter and search for it
you can add it in the comment and then put the customer by the action that searches for the phone in the text of the comment
Vitaly Volodymyrovych Pcholkin wrote: 2. Is it possible to insert a file into the process so that it is not downloaded, but listened to as missed calls?
no, it is necessary to make finishing touches - 2 hours
The work has been implemented the only other thing noticed is that you have a file type with the entry application/octet-stream and to listen in the browser you need audio/wav or audio/mp3 or ogg type
Thank you, regarding the format, the support answered the following: application/octet-stream is not the file itself, but the technology by which these files are sent to you. If very simplified - a box to preserve the integrity of the file. The audio itself is saved in *.wav format That is, theoretically the file itself should be suitable, please tell me. There is no possibility to receive the file in another format.
Ustimenko Igor OneBox production wrote: The work has been implemented the only other thing noticed is that you have a file type with the entry application/octet-stream and to listen in the browser you need audio/wav or audio/mp3 or ogg type
Ustimenko Igor
[Ustymenko Igor #9] please explain how the update works?
Vitaly Volodymyrovych Pcholkin wrote: Thank you, regarding the format, the support answered the following: application/octet-stream is not the file itself, but the technology by which these files are sent to you. If very simplified - a box to preserve the integrity of the file. The audio itself is saved in *.wav format That is, theoretically the file itself should be suitable, please tell me. There is no possibility to receive the file in another format.
made more corrections try on new sheets
try on new sheets
Igor Ustimenko] made more corrections try on new sheets
Thank you, the voice worked! What about determining the number from the initial request? How to identify a number that is in the subject of the letter and not in the body... Thank you!
Igor Ustimenko]
try on new sheets
Thank you!
Vitaly Volodymyrovych Pcholkin wrote: I am asking for help in creating a PREG template for creating a process with the ability to search for a client in contacts. I use the block Turn a letter into a process, by which you need to create a process and find a contact, if it exists, or create a new contact (nounname). 1. It is necessary to extract the phone number that is in the subject of the letter and search for it
This is
This is
Igor, congratulations! I remind you about question 1, the solution for which was not found, namely the creation of a PREG template for identifying the client by phone number, which is included in the subject of the letter. Please help, because it makes work processes very difficult. Thank you
Thank you
