Action didn't work
In the task https://topbox.1b.app/29034/ at the stage https://topbox.1b.app/admin/shop/workflowstatus/504/action/new/ the action https://prnt.sc/8pv4cjjW2Nqi is set which should not allow moving to a stage if the https://prnt.sc/9ece1magMT3Y field is not filled in. In the task, the "Receipt ID" field is not filled in, but the task has moved to the "Reverification" stage. Therefore, the "Check fields are complete" action did not work.
The task was transferred automatically to the "Reverification" stage from the "Rejected by client" stage https://topbox.1b.app/admin/shop/workflowstatus/602/action/new/, and the action was transferred to https://prnt.sc/ByrVyRlAvI_H.
Please correct the logic of the "Check fields are complete" action.
