Subtraction of k-th product due to action in the process
Here https://univer.1b.app/app/workflow/
action "Add products from one process to another" in the field "Additional action for products" add the item "When the ID of the product in the process matches, where to transfer, subtract the number of transferred products from the found product of the process". If the number is the same, remove the found product in the process.
How many hours are required for implementation?
Do you need to remove the product from the process from which you are copying the products?
20.09.2023, 17:19
