The check box "Exclude display of unfilled product fields in the process" does not hide empty columns when the "Display only products that have a field" check box is additionally applied
There is a business process block "Products by table"
There are checkmarks:
1. "Exclude the display of unfilled product fields in the process" (it hides columns that have no values)
2. "Display only products that have a field" (this setting shows only lines that meet the condition, specify the field and the value of this field)
When the product (table rows) was removed with the 2nd setting, there were empty columns in which there is no value, and according to logic, the first tick should have removed the extra columns, because they are empty, but it was not removed
Clarify this, is it necessary or is there a mistake?
There is a business process block "Products by table" There are checkmarks: 1. "Exclude the display of unfilled product fields in the process" (it hides columns that have no values) 2. "Display only products that have a field" (this setting shows only lines that meet the condition, specify the field and the value of this field) When the product (table rows) was removed with the 2nd setting, there were empty columns in which there is no value, and according to logic, the first tick should have removed the extra columns, because they are empty, but it was not removed Clarify this, is it necessary or is there a mistake?
Well, if you didn’t display a single product, then in principle everything is OK, the table with all columns should be displayed completely. ps with links to the process would be much easier.
The products are displayed, i.e. for example, out of 10 products, the table shows 1 product, but also shows all bells (empty) that do not actually belong to this product Maybe it works normally on the OS (we have MVP)?
If you have an example on OS where it doesn't work - please give such an example and I'll see what's wrong there, or write what to do. If you have an example with MVP, I can't give any information about it except that we are not engaged in consultations and improvements of this version. Maybe someone else will tell you, but most likely not.
