Check with your hoster because strange things are happening with the server.
When applying, add this screenshot:
Good day.
[file]19661[/file]
[file]19661[/file]
[file]19661[/file]
[file]19661[/file]
Yes, thank you. At that moment, when you started to check the operation of the system, there was a temporary malfunction in the hoster. But this was not the reason why boxing did not work. Thanks again for your help. Have a nice working day!!
The hoster put the server there, making a crazy load there, because of this load nothing could work, including boxing (even htop could not be opened, which needed almost nothing), because it simply did not allocate enough resources, but of course this is not was the reason why boxing didn't work. The reason is exactly something else and not that the server was objectively inoperative for an incomprehensible amount of time.
