It is not possible to add processes in any OneBox application. After clicking on "+", a blank screen appears. This has been going on for several days. What shall I do?
[file]19570[/file]
[file]19570[/file]
You have not created any BP in the "Task" in the system, therefore there is no addition form. Create or import a business process and everything will be ok
Path /app/workflow/
And if you take the "First type" BP, then you can create it there already, because there are stages
[file]19571[/file]
Path /app/workflow/
[file]19571[/file]
[file]19571[/file]
[file]19571[/file]
