Urgently! Fix the operation of the minute horseradish!
Urgently!!! Already on the third day, it does not work normally, the minute crown cannot work!
https://crm.tdp.com.ua/
Good afternoon. We do not support mvp product version. Switch to OS, then we can help you.
08.03.2023, 11:52
Артем
.dev
OneBox production wrote:
Good afternoon. We don't support the mvp version. Switch to OS, then we can help you.
what are you kidding? I am not asking you to complete anything. fix (return to the way it was) what you did and there will be no questions for you! until Friday 3-03 the problems started!
08.03.2023, 12:05
Artem wrote:
(return as it was) what was done
We didn't do anything on your server.
08.03.2023, 13:08
Артем
.dev
and we did not change anything, then what is the reason?
08.03.2023, 13:19
The fact is that kroner for some reason does not work.
We can see something on your server only in one situation: if you have an OS version
08.03.2023, 13:30
Artem, good afternoon,
we can take care of MVP maintenance, in this case please send the root access to your server to email.
08.03.2023, 14:05
Артем
Ihor Susiak
Sent to the post office
08.03.2023, 15:19
Is it normal for you to send root access to a server to a user on the Internet that you see for the first time?
08.03.2023, 15:24
Commentary is available in ua and not yet translated to the current language.
08.03.2023, 15:30
Артем
.dev
Is it normal for you to send root access to the server of a user on the Internet that you see for the first time?
You don't want to help! what are the other options?
08.03.2023, 15:35
there are always options
08.03.2023, 15:45
.dev
Well, partner - let them do mvp if there is a desire =)
08.03.2023, 16:10
