Parsing of goods from xml - price check
Congratulations!
They set up product parsing, check integrators through Automation and reported that everything is fine, but it doesn't work. Other prices work correctly.
It was recommended to write to the forum so that the developers can check whether the price is correct - https://ortomedika.com.ua/products_feed.xml?hash_tag=63b804be40f92e4537e5d64245e...
Literally:
...write an appeal to the forum with a link to this action, so that the developers can check whether the box can download the price using this link.
*(because there are links that do not give an error when "checking the file", but the system cannot read them.
As an example - a link from a supplier where there was a selection by categories (the link indicated the share categories=41,42,46, and the system did not load this price when the selection of categories was removed - the automation started immediately)
Please help to find the reason. Thank you!
