Does not store value in field with type
Today, the Senders field in Dealer Orders stopped filling in, we cannot enter a value in these fields https://prnt.sc/SDHE92tKCl4I, test order https://tcbs.crm-onebox.com/38997/#done, Please, very urgently! All work has stopped.
You have 2 fields displayed, you enter in the top one, and the bottom one frays it, in the Tech. info
06.10.2022, 17:19
Ліхачевський Віталій
Until today everything worked, nothing changed
06.10.2022, 17:22
What to do then?
06.10.2022, 17:27
In the Dealer's orders, the Senders field started to fill in, but the Senders field in the customer card is not filled in, for example, here https://tcbs.crm-onebox.com/app/contact/42711/
06.10.2022, 18:26
Commentary is available in ru and not yet translated to the current language.
06.10.2022, 18:28
In the contact card, it also allows you to fill in, but only after reloading the page. This is right? or can it be fixed?
06.10.2022, 18:33
fix it, figure out what the problem is
07.10.2022, 00:54
As before, you can fill in the Senders field in the Contact Card only after reloading the page.
07.10.2022, 11:50
reset cache
as it works fine for me now on your project
19.10.2022, 16:28
