Есть запрос по настройке системы? У нас есть партнеры-интеграторы которые с радостью вам помогут! Вы специально подготовили для вас список интеграторов.
Посмотреть список интеграторов
We need the ability to add the ability to repeat the task every day / week / month to the BP "Simple task" and "Call".
Example: every Monday we have a car inspection. We described in it everything that is needed and how the report should look.
Need to be able to create a similar issue every week on Monday with the same topic and description.
Or about calls: we have a call list and we call the same customers every day every week.
You need the ability to put in the BP "Call" the repetition of the call.
example: we have a client Romashka. we call him every Wednesday and we need the sales department every Wednesday in the calendar with tasks to have a BP "Call" to the Customer Romashka.
It is possible that this should be in the form of a separate block, where it is possible to select the frequency of repetition (date / day of the week / week / month / year).
Could you suggest how to implement this?
We need the ability to add the ability to repeat the task every day / week / month to the BP "Simple task" and "Call". Example: every Monday we have a car inspection. We described in it everything that is needed and how the report should look. Need to be able to create a similar issue every week on Monday with the same topic and description. Or about calls: we have a call list and we call the same customers every day every week. You need the ability to put in the BP "Call" the repetition of the call. example: we have a client Romashka. we call him every Wednesday and we need the sales department every Wednesday in the calendar with tasks to have a BP "Call" to the Customer Romashka. It is possible that this should be in the form of a separate block, where it is possible to select the frequency of repetition (date / day of the week / week / month / year). Could you suggest how to implement this?
Hello.
If you have OneBox OS, then you can do this using the block for creating tasks.
More details here https://crm-onebox.com/en/support/orders/9407-os---sozdanie-povtoryayushchihsya-zadach/
