Minimum reserve and RRP in warehouses
Нужно работать с базой товаров, устанавливать ррц и минимальный резерв?
В системе есть готовый компонент для этого! Посмотреть компонент
There is such a tab Minimum reserve and RRP in warehouses
https://crm.dobavki.ua/admin/shop/storage/report/reserve/
Here, the RRP is indicated for the products, we need to make it stand 0
I did not find how to do this in large quantities, tell me
Perhaps by some action or somehow massively make everyone RRC 0
Or clean up all these records en masse
At the moment it is possible only through the participation of the developer through the database.
Or modify the functionality somewhere (if you are interested, you can specify in what form you would like)
20.07.2021, 16:55
The client says that they did not record the RRP there
Found the action "Update minimum reserves in warehouses depending on sales", did it write down the RRP there? If so, is there anything I can do to stop recording?
20.07.2021, 17:16
No, there is no RRP entry in this action.
It is set by the RRP when adding a reserve manually through the product tab, in the reserve report itself when updating, when posting it can update
21.07.2021, 17:01
This is what I didn't understand
1. when adding a reserve manually through the product tab - where is this?) if you mean in the report itself here, then it’s clear https://crm.dobavki.ua/admin/shop/storage/report/reserve/
2. in the report on reserves actually during the update - I didn’t understand about the update, explain
3. When posting, it can update - in posting, there is no field for prr, what did you mean?
So that you clean the database one-time, is it 1 hour?
21.07.2021, 17:04
1. such a tab https://crm.dobavki.ua/admin/shop/products/78347/storage/reserve/
2. such a report https://crm.dobavki.ua/admin/shop/storage/report/reserve/ (click on RRC)
3. based on the RRP of the product
21.07.2021, 17:19
