Balance of the number of products in stock on a specific date
Greetings to all colleagues! Please tell me how in the "Warehouse" application, I need to upload a table with the balance of all products on a certain date, for example, I need the balances of products on March 31. Tell me how to do this
Good day. Are you interested in the total balances or the balances for each product separately?
29.04.2025, 12:53
lace
OneBox production wrote:
Good afternoon. Are you interested in the total balances or the balances for each product separately?
I am interested in a table for all products, i.e. for example I need to know what the total quantity of each product was on a certain date
example attached
29.04.2025, 12:56
https://tech-farming.1b.app/app/storage/tab/motiondate/ select a warehouse and a product - see how much of it was on date X in each warehouse. As far as I remember, nothing like this can be uploaded to files. In theory, you can make and save inventories, then you will be able to see data for each product separately on the day when you saved the inventory. Also, if you are interested, you can make a detailed upload in some report, but this will take about 8 hours of revision.
29.04.2025, 13:02
Svyridenko Igor Serhiyovych wrote:
lace
example attached
How much will an hour of finishing work cost?
29.04.2025, 13:03
1. The automatic translator translated the message strangely - see the ru answer
2. https://tech-farming.1b.app/app/storage/tab/monitor/?datefrom=2025-03-01&dat... storagenameid%5B%5D=6&ok=%D0%A4%D1%96%D0%BB%D1%8C%D1%82%D1%80%D1%83%D0%B2%D0%B0%D1%82%D0%B8 In theory, you can still view and download here. On the first date, filter the start date and in the “Initial quantity” column you will see the quantity in stock on this date. The checkbox “Show information about all surpluses that were on the cob date” in the filters must also be turned on
29.04.2025, 13:04
lace
example attached
thank you!
29.04.2025, 13:08
