Importing minimum reserve via file
Tell me what columns should be in the file and what they should be called in order to import the minimum reserve through the file in the Warehouse-Minimum Reserve module
22.08.2024, 18:01
you can also use the columns: code1c and articul as well as productid they are used to indicate which product the min reserve refers to
if you want to set the same Recommended selling price, then specify rrc and currency, where this is the price and the name of the currency, respectively
22.08.2024, 18:08
Maria
Here is the file. I just attached it here https://andser.crm-onebox.com/app/storage/tab/minreserve/?storagenameid%5B%5D=4&... and clicked the Add button, nothing changed
24.08.2024, 12:53
Judging by the file, you need to rename productid to articul or code1c according to what you added to the file
https://prnt.sc/KfwAwQI04bcS
26.08.2024, 09:44
