How to move a large amount of products to another warehouse?
Guys, please help me.
How to move a large amount of products/stock to another warehouse? I need to move about 20K products.
If you do it through the "Warehouse" app, there is no "Select All" button.
If you do it through the power supply, it won't load.
In the warehouse, you can load products from a file into the movement "Add products to the cart from an XLS file"
productid - column with product ID
count - column with quantity of goods
12.08.2024, 12:07
