Improvement: add switches to enable and disable movements
Guys, please consider a modification for the "Warehouse" application, namely: add switches to enable and disable "Can I move to this warehouse" and "Can I move from this warehouse" - https://prnt.sc/4Y6Bk7e8z886
Good afternoon. The checkboxes will be called a little differently, i.e. prohibit movement to this warehouse and prohibit movement from this warehouse. If a prohibited action is performed, an error will be generated. It will take about 5 hours for both ticks, issue an invoice?
28.02.2024, 17:49
