Is it somehow possible to secure the property purchased by the company for its activities by the employee? Considered 2 options. The first - using cells in the warehouse. For each employee, make a cell in one of the warehouses and move there the property attached to it. But there is a drawback here, the same property can change employees more than once, for example, the computer was in one store with one employee, then it was moved to another store to another employee (moved from one cell to another) and such a chain of transfers can be long But the warehouse log does not publish the history of all these movements, and this is very important.
The second option, I wanted to implement on business processes. For example, the store administrator receives 5 computers. This is reflected in the business process where he is a client. Next, he makes 5 sub-processes in this process where he moves them to 5 different employees. At the same time, the number of products in the parent process is reduced to zero, and thus nothing appears on the administrator. So you can continue to create sub-processes from one employee to another. And then in the report, select processes grouped by client (employee) and everything is displayed without problems. But everything would be fine if it weren't for another big problem. Some products have a complete set, for example, the same computer can be purchased in the form of different components, the purchase of which was in different processes for different customers (employees), then it is assembled from these components and transferred to another employee. Therefore, I cannot imagine how it can be done in the second way.
Thus, in the first way, the complete set is available on the cells through the production function in the warehouse application, but the history of movements of a specific product of the process is not available. And in the second way, the history of movements is available due to the nesting of sub-processes, but the complete set is not available. Advise what can be done in this situation.
Is it somehow possible to secure the property purchased by the company for its activities by the employee? Considered 2 options. The first - using cells in the warehouse. For each employee, make a cell in one of the warehouses and move there the property attached to it. But there is a drawback here, the same property can change employees more than once, for example, the computer was in one store with one employee, then it was moved to another store to another employee (moved from one cell to another) and such a chain of transfers can be long But the warehouse log does not publish the history of all these movements, and this is very important. The second option, I wanted to implement on business processes. For example, the store administrator receives 5 computers. This is reflected in the business process where he is a client. Next, he makes 5 sub-processes in this process where he moves them to 5 different employees. At the same time, the number of products in the parent process is reduced to zero, and thus nothing appears on the administrator. So you can continue to create sub-processes from one employee to another. And then in the report, select processes grouped by client (employee) and everything is displayed without problems. But everything would be fine if it weren't for another big problem. Some products have a complete set, for example, the same computer can be purchased in the form of different components, the purchase of which was in different processes for different customers (employees), then it is assembled from these components and transferred to another employee. Therefore, I cannot imagine how it can be done in the second way. Thus, in the first way, the complete set is available on the cells through the production function in the warehouse application, but the history of movements of a specific product of the process is not available. And in the second way, the history of movements is available due to the nesting of sub-processes, but the complete set is not available. Advise what can be done in this situation.
Gaidarov Ruslan Ismailovich wrote: And such a strap can be moved for a long time. However, the warehouse log does not show the history of all these movements, and this is even more important.
You are confusing something. In warehouses you can view the entire history of movements, starting with the receipt of the product. Try assigning a unique serial number to each product, then it will be easier to track all movements using the product serial number.
I already saw that it already has this functionality. If you use the option to use an employee as a warehouse. And the employee magazine is well displayed, and the history of when and with whom this product was.
