Goods are not reserved during the action process
Process https://one-box.shine-bright.com.ua/361150/. There is free stock in one of the warehouses.
Does not reserve goods either at the selected warehouse in the process or without a warehouse.
If you select a warehouse in action where the product is available, the product is reserved.
Why is a product not reserved if the action specifies a warehouse that does not have the product, given that the action says “The action tries to reserve the contents at the warehouse specified in the action, if there is not enough product, then we try to reserve at the warehouse specified in the process. Otherwise, it will trying to reserve at another warehouse"?
