Work with posting and sales in the Warehouse Journal
Good day.
Clarification is needed on the work of posting and selling in the Warehouse Journal.
In the order, we indicate the sales price and the input price (purchase price) https://prnt.sc/dzpHuKrhbRY3
At the stage is the action of posting, where it is noted what to do at the input price https://prnt.sc/eZfV-7MDv2KB
The magazine is held correctly!
Next at the stage, there is the action Sale https://prnt.sc/P0jFw1z-sqDA and here in the magazine it is held at the entry price! What is wrong!
This is how it appears in the log https://prnt.sc/-Ks7VGMl94Zw
The correct way should be: posting - entry price (purchase), sale - sale price
Tell me how to fix it so that it displays correctly?
Hello Nastya,
here, the internal feature of the box is that it is not worth entering the input price from the field, since it applies only to input processes, where you need to sell and see the input, which is calculated and displayed according to the rules with many options for setting.
Use the same Price that is in the product. Moreover, separate the processes into posting (outgoing process) and selling (incoming), doing different actions within the same process is not a good practice.
23.08.2023, 19:02
Hello, Igor.
Thanks for the tip, but the section on separate processes did not help! Tried many variations of the settings, but in any case, the selling price = selling price (
* the price of the product is nowhere to be found on the card, as each time it is added to the ordered manually (the price may be different each time)
24.08.2023, 10:07
let's take turns:
you make the arrival as a separate process, enter the price in the field like this: https://i.imgur.com/5E2M5C2.png
then in the action you do not check the box "Post at the input price (otherwise the posting will be carried out at the selling price)" - screen 2 https://i.imgur.com/r0ctu6G.png
in the parameters of the process, the output should be yes. screen 3: https://i.imgur.com/ugv4mzF.png
check, it will be delivered to the warehouse at the specified price.
Then only the sale.
24.08.2023, 16:31
Exactly as you wrote.
And then when selling, I indicate the same price https://prnt.sc/UqhuhqwUnSzw, when I perform the action Sold https://prnt.sc/a3etj0AGJp99
Then the price is taken anyway the same as the sale price https://prnt.sc/WGAn-sVHX98o
The only point where it could be my mistake is that I create a separate posting sub-process after switching to a stage and it goes unnoticed by the manager, but at this point the fields and data are copied from the parent, can this affect the sales price?
That is, the scheme is as follows: I specify the price in the field, carry out the posting in the subprocess, then change the price (in the parent) and carry out the sale, and accordingly the posting price = selling prices (
24.08.2023, 18:31
wait, the sales price is on the box, everything is correct.
And what exactly do you need - to see at what price it was bought? - then the Input Price is responsible for this. Display it in the order and it will be visible. By default, the FIFO amount is substituted there.
24.08.2023, 23:10
I want the purchase price to be the purchase price, and the sale price to be used when selling.
The option to display the input price and selling price in the ordered entry, carry out posting, sale - I tried it, writes the same price or in the input price or selling price field (depending on which tick is in the posting).
That is, the main thing I can't do according to the process is to have different posting and selling prices in the warehouse journal.
25.08.2023, 11:45
everything works for sure, let's call in the evening, you'll show me how to do it.
as an option - we have it configured on a test box, you must have access.
25.08.2023, 12:16
Thank you very much, I will try to test a few more times.
If nothing works - I will contact you)
25.08.2023, 15:03
We figured it out here, I will briefly describe: in the log of warehouse transactions, transactions are displayed only in relation to the warehouse, that is, even if we sold 500, then the entry will be displayed precisely for the entry price of the product that was sold.
If you need an income statement, seeing the margin is a matter of reporting.
05.09.2023, 20:25
Good day. Thanks for the clarification. For me personally, work of this kind, I mean capitalization and sales in the Warehouse Journal, is difficult. Working with my head is definitely not for me. That's why lately I started visiting this source https://vavsynergy.com/ru/job-location/belgiya/ There are current vacancies here, namely work in Belgium. By the way, on their website there is a filter where you can write down your preferences for work and select what interests you. In my opinion, this is the number 1 company in the field of formal employment in Europe.
27.02.2024, 12:24
