Here https://fr-auto.1box.link/app/storage/tab/balance/
In the "General balance in warehouses" block, you need to add the ability to add additional. fields of products with type number and floating point and summarize it by analogy as cost and purchase price.
How many hours do you need to implement?
Here https://fr-auto.1box.link/app/storage/tab/balance/ In the "General balance in warehouses" block, you need to add the ability to add additional. fields of products with type number and floating point and summarize it by analogy as cost and purchase price. How many hours do you need to implement?
In other settings of the "Warehouses" application, the setting "When viewing the balance, show columns with the amount by numeric additional product fields" has been improved - when it is turned on, amounts by numeric additional product fields are available for display in the balance table (the value of the additional field multiplied by the amount of the balance in the warehouse) .
The specification specifies what should be displayed in the "General balance in warehouses" block, and not in the "Balance of products in the warehouse". https://prnt.sc/foHqXobVTwrE Plz, fix it.
Plz, fix it.
