Greetings, dear developers!
In general, such an interesting refinement is required:
Suppose there is a product with a serial number in the warehouse (photo 1)
when we are in the process of ordering a customer, for example https://technoplay.1b.app/469/ we need the ability to search for a product serial by barcode - that is, in the interface field (may be custom, or what is already there) the warehouseman enters barcode scanner of the serial number - the numbers of the serial number are entered in the field accordingly - the system searches by !products of the process! the presence of such a serial number in the warehouse and affixes it to that! Process product! whose serial number was scanned. It also puts down a warehouse for the product on which this serial is located - but you can evaluate this separately if it takes extra time. And you need to make it so that if the same serial is scanned, then it is not added to a new product - one serial - one scan in the process. In the system,
Greetings, dear developers! In general, such an interesting refinement is required: Suppose there is a product with a serial number in the warehouse (photo 1) when we are in the process of ordering a customer, for example https://technoplay.1b.app/469/ we need the ability to search for a product serial by barcode - that is, in the interface field (may be custom, or what is already there) the warehouseman enters barcode scanner of the serial number - the numbers of the serial number are entered in the field accordingly - the system searches by !products of the process! the presence of such a serial number in the warehouse and affixes it to that! Process product! whose serial number was scanned. It also puts down a warehouse for the product on which this serial is located - but you can evaluate this separately if it takes extra time. And you need to make it so that if the same serial is scanned, then it is not added to a new product - one serial - one scan in the process. In the system,
Yes, I can make such a block or screw the settings to the existing ones. Takes about 3 hours.
Mazur Viktor Viktorovich SheBo wrote: so that if the same serial is scanned, then it is not added to a new product - one serial - one scan in the process.
here if there is no product or if the product with such a serial number is already put in the order, we can throw an error.
bu OneBox production wrote: Yes, I can make such a block or screw the settings to the existing ones. Takes about 3 hours.
poison, super, gun, pay here! Thanks!
bu
I ask you to make it into the existing one, if there are no restrictions on the length of the code and troubles (by the type that the article is trying to pull there, etc.). If there can be troubles and restrictions - then a new one
bu OneBox production wrote: Ustimenko Igor What do you need to donate to pay for the revision?
You can transfer to my account then I can transfer money for revision
bu
[Ustimenko Igor #9] What do you need to donate to pay for the revision?
That's what I'm talking about, I'll translate it within the framework of this topic Thanks :)
Ustimenko Igor
bu
done, thanks!
Ustimenko Igor
bu
done, thanks!
Good afternoon please confirm you see the payment Thanks
Ustimenko Igor
bu
Good afternoon
Thanks
SheBo wrote:
Ustimenko Igor
bu
Good afternoon
Thanks
