Action Turn a call into a process
https://crm.mebelok.com/admin/auto/action/minute/edit/
Action Turn Call Into Process (Unplaced Case)
We finalized the setting at the very bottom "Run once an hour (if not checked - once a minute)"
After that, the action began to be duplicated, it is displayed both once a minute and once an hour
As I understand it, this should not be so that it is displayed in both places.
We also noticed that the action "quickly" works, it felt like it worked once a minute, and it works, instead of once an hour as it is included. Please check this.
Good afternoon, due to the need to run in different crons, this action is present in the list of minute and hour actions.
A similar situation is, for example, with the action XML Product Integration (Export), which is also present in day actions
27.07.2021, 11:07
Zamogilny Dmitry
OK. He also wrote: they noticed that the action "quickly" works, it feels like it worked once a minute, and it works, instead of once an hour as it is included. Please check this.
Is the action only running once per hour? Or does it run once a minute and once an hour?
27.07.2021, 11:10
This action is configured in both minute and hour actions. The checkbox is both enabled and disabled in them to run both once an hour and once a minute.
27.07.2021, 11:21
Zamogilny Dmitry
Didn't understand anything
There is specifically this action
It includes a checkbox "Run once an hour (if not checked - once a minute)"
Will this action only run once per hour?
27.07.2021, 11:24
Korop Vladislav Pavlovich
Yes
27.07.2021, 11:44
