After updating on the OS, the Cabinet and its functionality do not work
Good day. I ran into a problem that after updating to the OS, my client's personal account stopped working.
As I understand it, after the transfer, everything should have been preserved that worked before.
I haven’t got used to the new system yet, so I couldn’t determine everything and everything, but I found out in person that the Add to Cart Button does not work, so it’s impossible to add the goods to the basket.
Also, the Client/Supplier stopped seeing their orders, which was previously configured.
GERA
EvoSmart Solution
Derkach Dmytriy
OneBox production wrote:
Hello. Got it for fix
Thank you, I'll wait for the correction))))
27.07.2021, 10:27
GERA
EvoSmart Solution
Derkach Dmytriy
Corrected
Tell me what you need to do what to check?
Restart on behalf of the client? or What
It's just that the goods have not been added and are not being added, and the orders are not displayed in the list either.
27.07.2021, 11:29
At night, your box will be updated and the problem will be fixed.
27.07.2021, 11:30
GERA
EvoSmart Solution
Derkach Dmytriy
Thank you for the information.
And in the report designer, all reports are displayed on Half the screen and there is no filter button in Those reports that have already been created individually. Will this also be updated?
27.07.2021, 11:39
strelec wrote:
Derkach Dmytriy
separate thread please
1 topic = 1 question
27.07.2021, 11:42
GERA
EvoSmart Solution
Derkach Dmytriy
strelec wrote:
Derkach Dmytriy
Okay, I'll create it now.
27.07.2021, 11:59
GERA
EvoSmart Solution
Derkach Dmytriy
No change ;(
I waited for the night, in the Morning I flew to the Office and immediately checked, but alas, everything remained the same.
28.07.2021, 09:30
Good afternoon. Try resetting your browser cache and check again
28.07.2021, 09:41
GERA
EvoSmart Solution
Derkach Dmytriy
Yes, after the cache, the goods began to be added to the basket, only orders are not displayed to the user.
Although I was assured that all settings were transferred Just before installing the applications that I want.
I did just that, but the orders are not visible ((((
28.07.2021, 12:37
By orders, please put in a separate topic
28.07.2021, 12:40
