Changed the API key and Box IP. All changes on the side of integrations have been made, but orders are not received by Boxing. Cron-minute, cron-hour don't work. Tell me how to solve the issue?
[file]7754[/file]
You need to go to your server and run the command: wget -qO- eth0.me the received ip address must be inserted into the api settings on the opencart. Now most likely ip is inserted incorrectly.
wget -qO- eth0.me
. OneBox production Premium Partner clack clack wrote: You need to go to your server and run the command: wget -qO- eth0.me the received ip address must be inserted into the api settings on the opencart. Now most likely ip is inserted incorrectly.
tell me how to start the cron if they stopped
OneBox production
Premium Partner
wget -qO- eth0.me
It's like that. You cannot restart crons on your server by yourself, this is considered interference with OneBox. All crons run automatically without client intervention.
Is there some kind of launch instruction to contact the hoster if the cron stops? Our cron stopped, but the hoster wrote that he did not know how to start it.
. OneBox production Premium partner clack clack wrote: If cron crashes, you can contact the forum. Cron automatically restarts after a few hours since the last unsuccessful launch.
OK thanks
OneBox production
Premium partner
OK thanks
