Apply discount in personal account depending on the amount
https://crm.dobavki.ua/client/
In the personal account, the client fills the order with goods, goes to the basket, then, depending on the amount of the order, in the personal account, you need to display the discount on the order and apply it.
That is, we need a setting where we will set the parameters:
If the order amount is more than X amount - apply the discount to the order and display it in the personal account
And set several such parameters, that is, there will be a different discount from a different order amount
We will set the discount in %
For example:
If the order amount is more than 1000 - 5% discount
If the order amount is more than 1500 - 7% discount
etc.
Need an evaluation
Good thing you need:
1. In discounts, make a choice whether it is possible to use a discount in the personal account (set the amount "FROM" and so on)
2. Refactor personal account when adding/editing a cart to add a discount + display it dynamically
It will take about 16 hours.
24.06.2021, 13:57
