Analogue of the product in production
https://mariemur.crm-onebox.com/
There is a product, it has a passport, which includes components for production, there can be many components. We do all of this with the Production action.
It may be that one material (component) of the passport is not available (ended) and instead we use another material, but it is not in the passport, creating a bunch of passports for different situations is not suitable, you need to have one passport
For such situations, there is a Product Analogs tab in the product card, we want to indicate their analogues for the components during production itself, if there is no component, so that the action looks at the analogues of the component which is not present and if there is, it performs production, I hope the essence is clear
Need an evaluation
Hi. In 25 hours, you can cut such logic into the actions of production, picking and unpacking.
04.05.2021, 16:36
T-34
In such situations, the quantity of goods will be taken into account that which is indicated in the main component and that quantity will be applied to the analogue, right?
07.05.2021, 13:16
Vlad, can you give a link to the status where you have this action configured?
21.05.2021, 15:49
snowball
https://mariemur.crm-onebox.com/admin/shop/workflowstatus/144/action/new/
21.05.2021, 15:51
