Evaluate the improvement by sorting in the client's office
Boxing https://cabinet.b2bframes.com/
In product page settings https://cabinet.b2bframes.com/admin/shop/boxclient/15/interface/
You need to sort by product creation date, new products on top.
Please rate 2 options:
1) just tick
2) setting (as in the product table , but available only in the admin panel, will work for everyone) to select 2 sorting options, at the moment you need:
- date of creation
- balance change date - if the product was out of stock, and then it was credited to the warehouse, then such product should get to the top of the list and sorted by date, from new to old
1. 1h
2. You can make a choice of sorting directly in the filters in the lx block
- creation date 2h
- balance change date - 4h
24.03.2021, 16:30
OneBox Corp - Інтегратор
Treebeard
- creation date 2h
and if inside, so that it was impossible to change the client? does the score change?
24.03.2021, 17:02
In the block in the settings to choose? 1 hour on the creation date and 4 hours on the balance change date
24.03.2021, 17:14
Treebeard
yes, that's right.
Thanks
24.03.2021, 17:19
Treebeard
But the point is to sort by two parameters at once
24.03.2021, 17:20
How is that? Who is more important?
24.03.2021, 17:27
Treebeard
You need to make 1 filter, which in paragraph 2, it closes the need for the 1st paragraph
If the client will do the sorting himself, will it be a button or a drop-down list?
24.03.2021, 18:46
Filter or sort? You wrote above about sorting, but here it’s about the filter
25.03.2021, 12:52
Dmitry
sorting, sorting only
25.03.2021, 13:32
I don’t understand how sorting “date of change of the balance” covers the needs of sorting by the date of creation of the product
26.03.2021, 11:03
Dmitry
It doesn't matter...)) What will it look like?
26.03.2021, 14:19
Let's do it at your convenience. We can make a field with a choice of sorting, such as: By name (or whatever it is by default), By product modification date. You choose sorting, the page reloads and the products are sorted as you chose
29.03.2021, 11:57
We need to make a button to which we will give a name (this is America, no one will understand Russian names), for example, “New Arrivals”, when you click on the button, we sort by the date the balance was changed (as described above).
+ it is necessary that the filters do not fly off, that is, it can be filtered and sorted.
Is it still 4 hours?
07.04.2021, 19:12
Sukhanitsky Andrey
Integrator Premium partner
Dima, please clarify the assessment, we really want to make improvements
08.04.2021, 16:48
Sukhanitsky Andrey
12.04.2021, 11:40
Uncle, I couldn't answer you. In closed topics, only admins can. Still the same 4 hours
12.04.2021, 11:47
thank you, I need an invoice
12.04.2021, 11:49
Any news on the issue?
22.04.2021, 16:23
while only put up, did not do
23.04.2021, 10:40
Thanks, we're waiting
23.04.2021, 17:02
What about this task, when can we expect?
28.04.2021, 16:16
Checked it works
04.05.2021, 12:25
