Select all in the product
https://rozpakui.crm-onebox.com/admin/shop/products/45338/edit/
You need to make a "Select All" button in the video cards https://rozpakui.crm-onebox.com/admin/shop/products/45338/edit/
And then you have to choose 36 positions by hand
Can this be improved? If yes, please rate.
Selecting all will mean choosing not a few dozen items that have loaded before further scrolling through the list, but choosing all the products in the box, be there 100,000 for example. They will need to be saved and uploaded to the same field. How expedient is this? I don't think so far. What are your arguments?
03.03.2021, 14:22
or do you mean select only 1 item?
03.03.2021, 14:23
Bye cancel
03.03.2021, 15:32
in pursuit, now, if something were chosen here
https://rozpakui.crm-onebox.com/admin/shop/products/45338/related/
it would be possible to figure out whether it is possible to pull such products into the multilist
in the example, how to define cards for a given product?
03.03.2021, 16:00
