I live!
I add a task to the process 'Approve payment for goods to the process'
The product tables have the 'Amount of payments for the product (paidsum)' field
How to take access to these values - how to change?
[file]3952[/file]
[file]3953[/file]
I live! I add a task to the process 'Approve payment for goods to the process' The product tables have the 'Amount of payments for the product (paidsum)' field How to take access to these values - how to change?
Hello. As far as I can see, the value of the specified field is not used anywhere in the system as a variable. I can evaluate its refinement - just specify where exactly you want to use it?
Hello.
Tyndyk Maxim Vadimovich Administrator wrote: Hello. As far as I can see, the value of the specified field is not used anywhere in the system as a variable. I can evaluate its refinement - just specify where exactly you want to use it?
Not sensible! Why are these data given, if they cannot be stopped???
Hello.
There is a lot of data in the system that cannot be used as variables. And everything is quite simple - clients come and order the completion of the field, but they do not need the variable of this field - so it is not finalized. What was ordered - then finalized. In this case, counting and output in a table/report.
Vyhid z dana situation - two arithmetic di ї, but why create an adventurousness on the system with additional rozrahunki? How can you work for help even with the right tools ??? Is it possible for me to introduce a bonus into the system?
I don't understand what you want from me now? If you need to use this variable somewhere (document / action or something else) - specify specifically, I will evaluate the improvement.
Tyndyk Maxim Vadimovich Administrator wrote: I don't understand what you want from me now? If you need to use this variable somewhere (document / action or something else) - specify specifically, I will evaluate the improvement.
Not everything needs to be paid for!
We can make minor improvements at our own expense only for paid cloud users. There was a topic about this earlier from the management on the forum, the conditions are written there.
