,the site is not working
bachu at once pracyuє
27.02.2021, 15:37
As far as I understand, there were problems with VPS, logs stopped being recorded in the system from Feb 27 14:00:01.
Feb 27 14:00:01 rovo systemd: Started Session 707457 of user root.
Feb 27 15:30:30 rovo kernel: Initializing cgroup subsys cpuset
Feb 27 15:30:30 rovo kernel: Initializing cgroup subsys cpuacct
Feb 27 15:30:30 rovo kernel: Linux version 3.10.0-957.27.2.el7.x86_64 (mockbuild@kbuilder.bsys.centos.org) (gcc version 4.8.5 20150623 (Red Hat 4.8.5-36) (GCC)) #1 SMP Mon Jul 29 1
Feb 27 15:30:30 rovo kernel: Command line: BOOT_IMAGE=/vmlinuz-3.10.0-957.27.2.el7.x86_64 root=UUID=18d3ec94-c464-40c5-a215-839aa0515c1d ro crashkernel=auto biosdevname=0 net .ifname
Everything worked only after reboot Feb 27 15:30
reboot system boot 3.10.0-957.27.2. Sat Feb 27 15:30 - 19:49 (04:18)
Now the tables in the database are broken.
Feb 27 15:34:19 rovo.org.ua mysqld[2161]: 2021-02-27 15:34:19 139749847615232 [Warning] Checking table: './db_rovoorgua/searchstandart'
Feb 27 15:38:56 rovo.org.ua mysqld[2161]: 2021-02-27 15:38:56 139749692147456 [ERROR] mysqld: Table './db_rovoorgua/searchproduct' is marked as crashed and should be repaired
Feb 27 15:38:56 rovo.org.ua mysqld[2161]: 2021-02-27 15:38:56 139749692147456 [ERROR] mysqld: Table 'searchproduct' is marked as crashed and should be repaired
Feb 27 15:38:56 rovo.org.ua mysqld[2161]: 2021-02-27 15:38:56 139749692147456 [Warning] Checking table: './db_rovoorgua/searchproduct'
Feb 27 16:12:02 rovo.org.ua mysqld[2161]: 2021-02-27 16:12:02 139749690304256 [ERROR] mysqld: Table './db_rovoorgua/searchcategory' is marked as crashed and should be repaired
Feb 27 16:12:02 rovo.org.ua mysqld[2161]: 2021-02-27 16:12:02 139749690304256 [ERROR] mysqld: Table 'searchcategory' is marked as crashed and should be repaired
Feb 27 16:12:02 rovo.org.ua mysqld[2161]: 2021-02-27 16:12:02 139749690304256 [Warning] Checking table: './db_rovoorgua/searchcategory'
Feb 27 17:45:56 rovo.org.ua mysqld[2161]: 2021-02-27 17:45:56 139749693683456 [ERROR] mysqld: Table './db_rovoorgua/searchbrand' is marked as crashed and should be repaired
Feb 27 17:45:56 rovo.org.ua mysqld[2161]: 2021-02-27 17:45:56 139749693683456 [ERROR] mysqld: Table 'searchbrand' is marked as crashed and should be repaired
Feb 27 17:45:56 rovo.org.ua mysqld[2161]: 2021-02-27 17:45:56 139749693683456 [Warning] Checking table: './db_rovoorgua/searchbrand'
27.02.2021, 20:01
What's the cim work???
28.02.2021, 11:16
Needs to be fixed.
If we do this we have 1 hour.
28.02.2021, 13:46
Let's work
Don't get lost?
After a pardon like https://crm-onebox.com/en/support/stock/7362-pomilka-z-oprihoduvanyam-tovara-tov...
will not vilaziti?
What robiti shob did not happen again?
02.03.2021, 08:52
Paid.
When will you be corrected?
24.03.2021, 13:58
Today 24.03.2021
Responsibilities no longer appear in the supplier's card
Although Voni Vіdobrazhayutsya in the process https://rovo.org.ua/admin/customorder/order/981601/edit/
24.03.2021, 14:13
Good evening.
The integrity of the database has been restored.
25.03.2021, 21:06
Wrongly restored lost Our obligations (balance)
https://rovo.org.ua/admin/shop/users/39001/
https://rovo.org.ua/admin/shop/users/1889/
It is necessary to renew duties.
When will you fix it?
26.03.2021, 11:51
You had problems with the server and database on 02/27/2021.
"Our obligations (balance)" stopped showing on 03/24/2021
Buchkovsky Rostislav Vasilievich wrote:
Today 24.03.2021
These are unrelated questions.
Create a new topic with your question and you will be answered.
26.03.2021, 14:17
What is the essence
If it was carried out, tsі operations goiter knitting were correct.
and after that, the tables were corrected. It got wrong.
04.04.2021, 10:44
