1. Great, it fits, you don’t need to delete anything in the settings, just add the ability to search for the brand + article link
https://prnt.sc/zuyl0x. Please send an invoice for payment
2. Purely search - yes, we can. But when it comes to any operations, for example, posting or reserving in a warehouse, it is necessary for the system to search for a brand + article in a bunch, and not just an Article or Name that are available for comparison. Example: we are using the standard "Product Import Block", there you can select the appropriate column and match it with the criteria in OneBox
https://prnt.sc/zuz9fh . But this list does not contain the Brand field, which is stored by the Directory
https://psauto.crm-onebox.com/admin/shop/brands/ . How do we add the brandname system field to the selection in this menu?
As an option, of course, you can create an additional field for the product card using this
https://psauto.crm-onebox.com/admin/shop/orderproductfield/ , as we did, but I don’t want to use this mechanism through crutches, because all the tools in system are available, we just need to configure them.
3. Can you check 2 items in the automation settings?
https://prnt.sc/zv15zh :
PSauto.com.ua/Update status of process products
PSauto.com.ua/Remove deleted process products from an order on the website
This was a revision, it seems to us that in it the data is also sent to the site using only one "Article" key. If yes, it will be possible to do, as for point No. 1 - send a bunch of Brand + Article in order to change the status of products or delete them. Those. there are no questions about the automation itself - it works properly, just to eliminate problems in the future, we want to play it safe.
Thanks in advance, we will wait for your answer!
