OneBox - campshop.com.ua
OneBox - rybalkashop.com.ua
Product card is not saved (gives an error) [file]2690[/file]
Problem in automation for products [file]2691[/file] in actions when saving a product card. When you enable Fill in SEO product fields based on the product card template [file]2692[/file], templates for SEO titles are filled in and these settings are the cause of the error. When these settings are turned off, the product card is saved without error.
The errors for both boxes are the same.
OneBox - campshop.com.ua OneBox - rybalkashop.com.ua Product card is not saved (gives an error) Problem in automation for products in actions when saving a product card. When you enable Fill in SEO product fields based on the product card template , templates for SEO titles are filled in and these settings are the cause of the error. When these settings are turned off, the product card is saved without error. The errors for both boxes are the same.
