Good afternoon! We have created duplicate categories, they are empty and need to be deleted. BUT if you take the "categories" from the menu, it's not clear what to delete, because the contents of the category are not visible. Are there any other ways to filter or rename empty categories to remove them?
https://prnt.sc/w3tth1
https://shopforcars.crm-onebox.com/admin/shop/category/manage/
Good afternoon! We have created duplicate categories, they are empty and need to be deleted. BUT if you take the "categories" from the menu, it's not clear what to delete, because the contents of the category are not visible. Are there any other ways to filter or rename empty categories to remove them? https://prnt.sc/w3tth1 https://shopforcars.crm-onebox.com/admin/shop/category/manage/
If you choose to combine folders, then automatically transfer the same products to the folder if you want to get rid of them. if you want to know exactly what the folder is and what is in the product
