extra field error when copying
integrator
integrator.com.ua
so it is recommended to work not with automation of products (because of the skin time when changing data in goods and scoring the history of changes), but with the functionality of the formula of natsіn. in the rules of the price, choose which will be only for your type of price Prom/Rozetka
video report https://www.youtube.com/watch?v=9S-TqKMPw5E
04.12.2020, 16:54
I ask you to give an answer specifically for the problem I described above, and with the usual copying of the product, this problem does not completely (I'm not satisfied with the fact that it does not generate new barcodes) Thank you in advance for your help!
04.12.2020, 17:04
integrator
integrator.com.ua
antip
Client wrote:
I ask you to give an answer specifically for the problem I described above, and with the usual copying of the product, this problem is completely absent (I am not satisfied with the fact that it does not generate new barcodes) Thank you in advance for your help!
If it is necessary to supply a bug or a bug (on the screen you can’t see how the very same thing was done in the automation of copying) - then it is necessary to check the support of the OneBox manufacturer.
04.12.2020, 18:33
OneBox Corp - Інтегратор
antip
Client wrote:
Hello, when copying a product, the fields cannot be changed, please help me solve the problem
copy action https://box.optodess.com.ua/admin/shop/products/copy/
fields are autofilled from here https://box.optodess.com.ua/admin/products/action/update/edit/
Hello.
It is not clear what exactly does not change?
The fields that you specified will be filled in in any case according to the formulas that you specified in them, in order for the price to change, you need to change the values of these fields https://prnt.sc/vw26j3
05.12.2020, 00:19
Sukhanitsky Andrey Vladimirovich
Integrator wrote:
antip
Hello.
yes, it should, but it doesn’t change for the copied one, I showed it on the video
05.12.2020, 09:52
There is definitely a problem here: either something else is copied along with the fields, or this is a bug.
In this case, only the price level is copied, namely the Prom/Rozetka price
I didn't find anything at all that could influence this.
This product by copying https://box.optodess.com.ua/admin/shop/products/17005/edit/ - does not change here
https://box.optodess.com.ua/admin/shop/products/copy/ copy item 16991
And this product https://box.optodess.com.ua/admin/shop/products/17007/edit/ via the button https://prnt.sc/vwjujs - everything is ok
05.12.2020, 23:21
thanks for checking, so what can we expect some solution to the problem?
06.12.2020, 11:00
Hello, thanks for your help!
Bodyako Dmitry
Employee wrote:
Hello. Try copy now
17.12.2020, 18:30
