Payments in personal account_Closing the payment window
At the time of the client's payment from the personal account - the following processes are created - https://crm.ohholding.com.ua/admin/customorder/oplati-dogovorov/?searchLine=
It is necessary to check "Do you really want to close the payment window" with the Yes / No buttons at the moment when the user tries to close such a payment window after switching to it from the personal account
If the user clicks "Yes" - delete the process in the list https://crm.ohholding.com.ua/admin/customorder/oplati-dogovorov/?searchLine=
Unfortunately, this description does not make it clear what, where and in what form it is necessary to implement. You provide a screenshot to a third-party service (in this case, LiqPay), but do not indicate what and where needs to be improved on the OneBox side.
Please describe your need in a more detailed form.
16.11.2020, 11:48
I clarify - the client uses blocks: https://prnt.sc/vjxurz
When he selects payment in them, he is transferred to the payment page and creates a process https://crm.ohholding.com.ua/admin/customorder/oplati-dogovorov/?searchLine=
If it closes the payment window, the process still remains.
Accordingly, you need "protection from a fool" and the removal of the process as described.
Is it possible to link to the payment window if the user tries to close it with a Yes/No window?
Is it possible to delete the created process if the user answered - Yes?
16.11.2020, 11:58
That is, you want some kind of dialog box to appear when you try to close the page of a third-party payment service? If yes, then it cannot be done.
16.11.2020, 14:41
Does the payment come later in this process? If so, can it make an action that after some time will check whether there was a payment and if not, will it delete the process?
16.11.2020, 14:43
No, the payment comes in another process. But in theory, you can tie it to a certain Parent. Or add to the payment block to which parent to knit, since the payment will be made from the process page in the personal account. There is a contract number field - this is additional. field, it is +/- unique. + finalize the action that you propose. Is it possible? What is the assessment?
17.11.2020, 18:42
if you set it like this - OK
you will need to find the process in a certain BP by comparing the value of the additional field (contract number entered) - and bind it as a parent - if so - then 2 hours of revision
payment verification action in the current process N time field and deletion in case of absence - 4 hours
18.11.2020, 12:48
