finalize hourly action "Integrate CSV Products (Export)"
need to improve the action Integration of products CSV (Export)
1. make it possible to set the output order of the fields (you can add the "Sort / column number" column, in which the user will enter the number of the column number in the final file. This parameter should be available both for system fields http://prntscr.com/uzu1jh , and for additional fields http://prntscr.com/uzu24k). All fields that are uploaded to the file (both system and additional, will need to be arranged sequentially, according to the values \u200b\u200bspecified in the "Sort" column)
2. for the [date] variable, you need to add the ability to specify the date/time format of the displayed value http://prntscr.com/uzu402
3. add a field to the action - a character-separator of values in the file. The delimiter is now comma. you need to set the separator "semicolon". the character entered by the user must be used as a column separator in the resulting file http://prntscr.com/uzu6wo
4.
Перегіняк Олександр
Oneboxconsulting (интегратор)
Ustimenko Igor OneBox CTO wrote:
7h
when can you do it?
28.10.2020, 10:04
Pereginyak Alexander
7h
when can you do it?
from the moment of payment of the invoice - 3 days
28.10.2020, 10:29
Перегіняк Олександр
7h
when can you do it?
issue an invoice. ready to pay
28.10.2020, 13:19
Перегіняк Олександр
the bill is paid. put into work
28.10.2020, 16:42
Перегіняк Олександр
received payment? are you doing the task?
29.10.2020, 13:00
29.10.2020, 14:49
