Change base currency
But in your system there is a lot of data that is recorded relative to the base currency UAH - changing the currency will not change the essence and you will have problems calculating amounts and liabilities in the system.
Are you sure you want to do this?
13.03.2025, 08:48
#156508
Yes, please change.
13.03.2025, 09:10
I changed the currency name to PLN and set it as the system currency.
Do not forget to change the exchange rates relative to it and edit all entities that are calculated relative to the UAH currency - I warned above about the consequences of such manipulations on the data system.
13.03.2025, 09:36
#156508
Thank you! We're changing!
13.03.2025, 10:08
#156508
The price conversion is still calculated in hryvnia.
For example, 1032912 - the supplier's price in euros, the product - in zlotys. The price is calculated like this now - euros are converted into hryvnias and then back into zlotys.
How to make the price multiply from euro to zloty. To do this, the base currency was changed, but the conversion still goes through hryvnias
13.03.2025, 10:53
I warned you of the consequences.
You now need to change currencies, exchange rates for these currencies in each entity, etc. in orders/payments/products and other entities.
13.03.2025, 10:54
and I wrote this
Maksym Vadimovich Tyndyk
Don't forget to change courses relative to it
this means here https://knigarnia.1b.app/app/currency/ the PLN rate should be 1, and other currencies should have a rate relative to it, that is, how much EUR is relative to zlotys (similarly to what it was relative to the hryvnia)
13.03.2025, 10:57
#156508
should PLN be 0 or 1?
13.03.2025, 11:03
1
13.03.2025, 11:05
#156508
Everything seems to be working correctly! Thank you very much for your quick help!
13.03.2025, 11:16
