The cost of the data cleaning program in the case of using licenses
There is a box with payment per user.
In the application it is written:
"There are no additional charges. You only pay for the OneBox user."
But when you click the "Install" button and select the appropriate box with payment per user, it shows that you need to pay $39 per month.
This is an error in the display, and dare you put it on the box https://askoart.1b.app/ without waiting for payment for this application?
this is a translation error - it will be corrected
09.09.2024, 22:56
Although not - you can bet - the funds will not be written off
10.09.2024, 07:34
