In MP, when creating a process, it gives an error if you attach a screen
I can't attach the screenshot here because I'm writing the task from my mobile
You can check if it doesn't work, I'll attach a screenshot
Куприян Владислав Валерьевич
Boxing baza.cn.ua
04.10.2020, 00:10
Here is the error https://prnt.sc/usme3x
04.10.2020, 00:12
https://baza.cn.ua/admin/customorder/issue/23569/edit/ I got it. The mobile application shows such a message when the phone's Internet connection drops. Perhaps you had an unstable connection then, try to do the same with a good Wi-Fi
05.10.2020, 10:40
I checked, with good wifi it works fine like
05.10.2020, 11:06
