We increased the server parameters, but now the hourly crown does not work, how to reconfigure the parameters?
We increased the parameters (RAM was 4, it became 8), but the hourly crown works somewhat chaotically, the panel generally shows that it does not work)
Boxing on MVP
Please tell me what parameters need to be changed so that the system does not malfunction?
provide a link to your onebox
16.06.2023, 17:34
Юля
менеджер
Ustimenko Igor
Good day
The manager has forbidden to provide links
If you can, provide basic recommendations for setting up the server (what parameters to look at and what should be changed, if possible)
19.06.2023, 12:07
I cannot analyze your system to make recommendations
if it is difficult to provide a link, I will find it anyway by your ip address)
19.06.2023, 12:41
Say hello to Vladyslav Kupriyan
19.06.2023, 16:01
Юля
менеджер
The problem is solved
The solution is described here https://1b.app/ua/forum/business-processes-and-automation/17246-koli-vibaraiemo-... /#answer56032
21.06.2023, 10:19
