Помилка 500, допоможіть виправити
Доброго дня, бокс 1box.sverla.info
Помилка:
[2023-02-17 11:17:50]
host: 1box.sverla.info
url: /admin/shop/users/add/?phone=380964833150&eventid=27328&sourceid=0
contentID: shop-admin-users-add
point: /shop.starter.php
data: Array
[0] => 500
[1] => Executing error: Out of range value for column 'id' at row 1 in query: INSERT INTO `searchque` SET `id`='', `type`='user', `key`='13540'
[2] => /var/www/1boxsverlainfo/web1/web/packages/ConnectionManager/ConnectionManager_MySQLi....
[3] => #0 /var/www/1boxsverlainfo/web1/web/packages/SQLObject/SQLObject.class.php(1459): ConnectionManager_MySQLi->query('INSERT INTO `se...')
#1 /var/www/1boxsverlainfo/web1/web/packages/SQLObject/SQLObject.class.php(207): SQLObject->_query('INSERT INTO `se...')
#2 /var/www/1boxsverlainfo/web1/web/modules/search-fulltext/api/SearchFulltext_Handler_A... SQLObject->insert()
#3 /var/www/1boxsverlainfo/web1/web/modules/search-fulltext/api/SearchFulltext_Handler_U... SearchFulltext_Handler_Abstract->_addToQue('user', 13540)
#4 /var/www/1boxsverlainfo/web1/web/packages/Events/Events_Event.class.php(95): SearchFulltext_Handler_UserReplace->notify(Object(SQLObject_Event))
#5 /var/www/1boxsverlainfo/web1/web/packages/SQLObject/SQLObject.class.php(1371): Events_Event->notify()
#6 /var/www/1boxsverlainfo/web1/web/packages/SQLObject/SQLObject.class.php(218): SQLObject->_notifyEvent('User.insert.aft...')
#7 /var/www/1boxsverlainfo/web1/web/api/system/User.class.php(736): SQLObject->insert()
#8 /var/www/1boxsverlainfo/web1/web/contents/shop/admin/contact/users_add.php(108): User->insert(true)
#9 /var/www/1boxsverlainfo/web1/web/packages/Engine/Engine_ContentDriver.class.php(265): users_add->process()
#10 /var/www/1boxsverlainfo/web1/web/packages/Engine/Engine_ContentDriver.class.php(120): Engine_ContentDriver->displayOne('shop-admin-user...')
#11 /var/www/1boxsverlainfo/web1/web/packages/Engine/Engine_ContentDriver.class.php(77): Engine_ContentDriver->display('shop-admin-user...')
#12 /var/www/1boxsverlainfo/web1/web/packages/Engine/Engine.class.php(132): Engine_ContentDriver->getString('shop-admin-user...')
#13 /var/www/1boxsverlainfo/web1/web/shop.starter.php(123): Engine->execute()
#14 {main}
2h
you have a box and a problem in the database
25.02.2023, 03:34
