Hourly krone working time
Good afternoon. When switching to OS, the server resource was increased to:
RAM: 8192
Number of processors: 6
Now hourly crowns work longer than 3000 seconds, even on MVP it was a little less than 2400-2600 seconds.
What is the reason? 6 cores not enough for faster performance?
Also, judging by the top of slow actions, it is not clear where such a total duration of working out comes from.
Tomorrow morning, look, sorting did not work correctly there when the action > 1000 sec.
15.02.2023, 22:24
But in general, the processing speed should not have improved on the OS? Also, taking into account the addition of a processor resource.
16.02.2023, 01:02
If something works for you for more than 100 seconds, then the point is no longer in the code, but most likely in the fact that we are transferring information to another system. For example, we export goods to opencart, the server of which is far from the box server. This is not fixed by the new software version, it is fixed by a decrease in the number of transmitted data
16.02.2023, 11:09
well, as it were, import of goods from the database, which is not clear where. Sending requests to it can take more time than executing them.
16.02.2023, 11:11
Understood thanks
17.02.2023, 14:12
